Powerfast connectors
Suitable for conveyor, small motor and material handling applications, three and four-pin M16 powerfast connectors provide up to 15 Amps of current in a small molded body. The cordsets are available with a tray-rated, exposed-run PVC flexlife cable, and all connectors provide IEC IP67 protection and are rated for 600 VAC/VDC.
Suitable for conveyor, small motor and material handling applications, three and four-pin M16 powerfast connectors provide up to 15 Amps of current in a small molded body. The cordsets are available with a tray-rated, exposed-run PVC flexlife cable, and all connectors provide IEC IP67 protection and are rated for 600 VAC/VDC. Male or female straight connectors in standard and custom lengths, pigtails or extensions are available.
Turck, Inc.
www.turck.com
