Photoelectric sensors operate up to 250 V
Q45 universal voltage photoelectric sensors operate at 25-250 Vac, 50/60 Hz, or 12-250 Vdc (1.5W max).
Q45 universal voltage photoelectric sensors operate at 25-250 Vac, 50/60 Hz, or 12-250 Vdc (1.5W max). The sensor is available in opposed, diffuse (proximity), retroreflective, or convergent mode, as well as glass or plastic fiber-optic models with a choice of isolated solid-state output or electromechanical relay output. The sensors include a light/dark operate select switch, multi-turn sensitivity control, and system for quick and easy alignment.
Banner Engineering Corp.
www.baneng.com
Circle 372
