Bev Dry mounted bearings have no provision for relubrication and are designed to run longer that way. The synthetic grease used has twice the stability of standard products. Spring-loaded oil seals exclude contamination and retain synthetic lubricant.
Bev Dry mounted bearings have no provision for relubrication and are designed to run longer that way. The synthetic grease used has twice the stability of standard products. Spring-loaded oil seals exclude contamination and retain synthetic lubricant. Housing styles include pillow blocks, two and four-bolt flanges, takeups, and tapped bases. Sealmaster Bearings Div., Emerson Power Transmission
