Wash-Thru motor in sizes from 1/2-20 hp is designed for long life in harsh environments. Pressure encapsulated windings provide moisture protection, and electrodeposition primer protects against corrosion.
Wash-Thru motor in sizes from 1/2-20 hp is designed for long life in harsh environments. Pressure encapsulated windings provide moisture protection, and electrodeposition primer protects against corrosion. The motor also has a stainless steel shaft and nameplate, and electrodeposition-coated rotor. The Lincoln Electric Co., Motor Div.
