Magnetic flowmeter
The FMG3000 series magnetic flowmeter is an insertion-style magnetic flow sensor with no moving parts. All versions are constructed of corrosion-resistant materials to provide long-term reliability with minimal maintenance costs. The FMG3000 series does not require field programming. Jumpers can be set for pipe size and the maximum output will reflect 5 m/s for a 4–mA signal.
The FMG3000 series magnetic flowmeter is an insertion-style magnetic flow sensor with no moving parts. All versions are constructed of corrosion-resistant materials to provide long-term reliability with minimal maintenance costs. The FMG3000 series does not require field programming. Jumpers can be set for pipe size and the maximum output will reflect 5 m/s for a 4—mA signal. Compatible with the company’s line of installation fittings, sensor alignment and insertion depth are completed automatically. The versatile, simple-to-install flowmeters deliver flow measurement for pipe sizes ranging from DN15 to DN200 (0.5 to 8 inches). Flow velocity measurement is compensated for temperature by an integrated temperature sensor.
Omega Engineering, Inc.
www.omega.com
