Lubricant reduces bearing failures
Micropoly oil-saturated polymer helps stop bearing failures and reduces delays caused by equipment breakdown. The lubricant meets FDA specifications and has been approved by USDA for use in food processing equipment.
Micropoly oil-saturated polymer helps stop bearing failures and reduces delays caused by equipment breakdown. The lubricant meets FDA specifications and has been approved by USDA for use in food processing equipment. Since it contains nearly twice as much oil as an equivalent volume of grease, relubrication of bearings is often not necessary. The lubricant is solid, which enhances bearing protection provided by seals.
PhyMet, Inc.
Circle 390
