Problem: A valve, immersion heater, or similar item, must be removed from the bottom of a hydraulic reservoir. Draining the reservoir is a time consuming nuisance.
Solution: Instead of draining, fill the reservoir as full as possible, and seal all inlets tightly with duct tape. Place a pan under the item to be disconnected, and quickly remove and replace the component. (This approach has worked successfully on a 300-gal. reservoir, opening a 2 1/4-in. line with only 2-3 gal. of fluid dropping to the pan.)
Contributor: Ronald R. Gould, VP/Engineering, Advance Lifts, Inc., St. Charles, IL
Each item published will earn the sender $35. Send your tips to: Simple Solutions Plant Engineering magazine 2000 Clearwater Dr. Oak Brook, IL 60523-8809 e-mail: [email protected]
