High-performance Cat 5e cable
This Cat 5e cable features a highly flexible flat profile and an exclusive, extruded silicone encapsulation. While meeting or exceeding all electrical and signal requirements for the Cat 5e standard, this version excels with physical and environmental attributes.
Cicoil Cat 5e cable features a highly flexible flat profile
all electrical and signal requirements for the Cat 5e standard, Cicoil’s
version excels with physical and environmental attributes. Temperature rating
is a -65 C to 260 C range and is flame resistant. They are submersible, with
excellent resistance to steam, salt water and de-ionized water; and are further
resistant to chemicals, acid, oils, alcohol and ozone.
The Cat 5e cables were created to meet the increased demand
of professionals who need a rugged, reliable, portable and flexible network
cable solution. They excel in the field where environmental contaminants can
damage or degrade common cables.
In repeated flexing applications, these Cat 5e cables
feature a repeated bend radius of just 0.9 inch, and a cycle life exceeding
10,000,000 repetitive flexing. It also features a Durometer rating of Shore A,
65. In addition, they are approved by NASA for space flight, and exceed
outgassing specifications for vacuum and space use. They are rated for
radiation exposure to 10-7 Roentgens.
Cicoil
www.cicoil.com
