A new hand pallet truck has an articulated steer axle that helps maintain maneuverability on uneven surfaces or with unbalanced loads. The control handle has an indexed control trigger that switches between lift, lower, and neutral settings.
A new hand pallet truck has an articulated steer axle that helps maintain maneuverability on uneven surfaces or with unbalanced loads. The control handle has an indexed control trigger that switches between lift, lower, and neutral settings. A 4-p brochure describes the 5000-lb capacity truck. Mitsubishi Forklift Trucks, www.mit-lift.com
Circle 254
