Oil and Gas
Double up on solenoid safety
Adding two solenoid valves to a safety instrumented system keeps equipment, facility and personnel safe and the system online.
Leonard W. Moore, founder of Moore Industries-International passes away at 85
Leonard (Len) W. Moore, P.E., founder and owner of Moore Industries-International Inc., an industrial and automation control company, passed at the age of 85.
Advanced process control improves refinery, chemical plant operations
Next-generation advanced process control (APC) shatters processing barriers for process facilities.
Leverage digitalization for asset integrity management
Select the right management technologies for modernization.
Report finds cybersecurity basics still not being practiced by companies
A report from Applied Risk found that cybersecurity basics are still not being practiced by many companies, which is increasing their risk for potential attacks as untested technologies continue proliferating critical infrastructures.
Integrated virtual control system announced for processing, oil and gas applications
Honeywell unveiled Experion PKS Highly Integrated Virtual Environment (HIVE), which is designed to help engineers maintain industrial control systems (ICSs) for chemical, processing, and oil and gas applications and simplify the overall process.
Liberating oil analysis data
Many factors can prevent end-users from getting more from their reports.
Understanding lubrication from the bearing’s perspective
Many factors can impact how proper use can avoid friction.
Clean oil is productive oil
The care of your lubricant stock is all about the basics.
Predictive maintenance gains greater significance in oil and gas industry
GlobalData's report on predictive maintenance finds oil & gas companies are increasingly relying on it due to aging infrastructure and volatile crude pricing.
