Energy harvester improves wearable electronics potential
An energy harvester has been developed that could make manufacturing embedded wearable electronics a viable reality.
By using the simple and easy fabrication process of hot pressing and tape casting, a new energy harvester could take the industry one step closer to being able to manufacture embedded wearable electronics.
The development actually lies in its simplicity, applicability, and durability, said Professor Seungbum Hong of the Korea Advanced Institute of Science and Technology (KAIST). Wearable devices are increasingly seeing greater use in a wide array of applications from small electronics to embedded devices such as sensors, actuators, displays, and energy harvesters.
Despite their many advantages, high costs and complex fabrication processes remained challenges for reaching commercialization. In addition, their durability was frequently questioned. To address these issues, Hong’s team developed a new fabrication process and analysis technology for testing the mechanical properties of affordable wearable devices.
For this process, the research team used a hot pressing and tape casting procedure to connect the fabric structures of polyester and a polymer film. Hot pressing usually comes into play when making batteries and fuel cells due to its high adhesiveness. Above all, the process takes only two to three minutes.
The fabrication process enables the direct application of a device into general garments using hot pressing just as graphic patches can be attached to garments using a heat press.
In particular, when the polymer film is hot pressed onto a fabric below its crystallization temperature, it transforms into an amorphous state. In this state, it compactly attaches to the concave surface of the fabric and infiltrates the gaps between the transverse wefts and longitudinal warps. These features result in high interfacial adhesion strength. For this reason, hot pressing has the potential to reduce the cost of fabrication through the direct application of fabric-based wearable devices to common garments.
In addition to the conventional durability test of bending cycles, the newly introduced surface and interfacial cutting analysis system proved the high mechanical durability of the fabric-based wearable device by measuring the high interfacial adhesion strength between the fabric and the polymer film. Hong said the study lays a new foundation for the manufacturing process and analysis of wearable devices using fabrics and polymers.
He added his team first used the surface and interfacial cutting analysis system (SAICAS) in the field of wearable electronics to test the mechanical properties of polymer-based wearable devices. Their surface and interfacial cutting analysis system is more precise than conventional methods (peel test, tape test, and microstretch test) because it qualitatively and quantitatively measures the adhesion strength.
ā€œThis study could enable the commercialization of highly durable wearable devices based on the analysis of their interfacial adhesion strength,ā€ Hong said. ā€œOur study lays a new foundation for the manufacturing process and analysis of other devices using fabrics and polymers.”
This article originally appeared onĀ ISSSource’sĀ website.Ā ISSSourceĀ is a CFE Media content partner.
Gregory Hale
Gregory HaleĀ is the editor and founder of Industrial Safety and Security Source (ISSSource.com), a news and information website covering safety and security issues in the manufacturing automation sector.
