DIN rail dc UPS
The 24 Vdc uninterruptible power supply is designed to provide maximum uptime and protection from unexpected dc power disruptions. It is intended for industrial computer, robotics, automation and process control applications.
The SDU DIN rail 24 Vdc uninterruptible power supply is designed to provide maximum uptime and protection from unexpected dc power disruptions. Intended for industrial computer, robotics, automation and process control applications, the UPS is available in 10- and 20-A designs with a choice of two battery modules. It mounts on a DIN rail in a control panel, or can be integrated into an enclosure or machine. Its compact modular design offers a 0-50 C operational temperature range. To assure reliable and economical power protection to 24-Vdc devices on the factory floor, it delivers the ride-through needed to allow sensitive equipment to safely shutdown during extended power failure, preventing costly data losses, work interruptions and equipment damage. UPS features include industrial-grade steel enclosure; flexible battery back-up expansion capabilities; LED indicators, alarms and self-diagnostic capabilities; optional dry contact I/O communication; and optional USB port. The UPS is UL 508 Listed, UL 60950-1 Listed and recognized and CE marked.
Sola/Hevi-Duty
www.solaheviduty.com
Plant Engineering
Plant Engineering Staff
