The EPS ProSense line of digital pressure sensors are designed for industrial pressure measurement and indication in both gas and liquid applications.
The EPS ProSense line of digital pressure sensors are designed for industrial pressure measurement and indication in both gas and liquid applications. EPS-series sensors are available with measuring ranges from vacuum up to 5800 psig. Selectable engineering units such as bar, mbar, kPa, MPa, inches of water column, and inches of mercury can be shown on the digital display. Encased in a stainless steel housing, the EPS-series sensors have a high IP67 ingress protection rating, and achieve their atmospheric pressure reference at the 4-pin M12 electrical connection. The 1/4-in. NPT male process connection allows for direct installation without requiring extra fittings.
AutomationDirect
www.automationdirect.com
