Company cuts component count in temperature measurement system for combustion plants
Bonnenberg & Drescher leverages flexible, fully integrated automation and measurement technology
Temperature measurement insights
  • Bonnenberg & Drescher leverages flexible, fully integrated automation and measurement technology.
  • Using modular systems helps increase the flexibility in what parts are used where.
  • Using electronic fuses helps cut cost and parts while still providing overcurrent protection.
Highly complex plants in energy, steel and other industries place high standards on any measurement and analysis technology. These demands include not only fast and precise data acquisition, but also a system design that is as flexible, expandable, cost-effective and space-saving as possible. This is precisely why Bonnenberg & Drescher GmbH relies on PC-based automation and measurement technology from Beckhoff for its acoustic gas temperature measurement (AGAM).
Aldenhoven, Germany-based Bonnenberg & Drescher specializes in process analysis and optimization and works primarily in combustion applications. The company was founded in 1971 and initially dealt with nuclear engineering projects, from the design and lifetime analysis of cooling systems and critical components to nuclear safety considerations such as radiation protection, radioactive emissions and their behavior in the environment. In the 1980s, its range of services expanded to include conventional power plants, with a particular focus on the analysis and optimization of combustion processes. The company has used the AGAM system for this purpose, as well as in waste incineration and blast furnaces, since the early 1990s.
The physical principle behind acoustic gas temperature measurement is simple: the speed of sound in a gas depends on the gas temperature – the hotter the gas, the faster the propagation speed of the sound waves. For accurate measurement of gas temperatures, several microphones are distributed around the boiler, which in turn generate a signal that is received simultaneously by all units. This is then used to calculate a 2D temperature profile of the gas in the boiler. One advantage of this method is the radiation-free measurement of the gas temperature, which is used to optimize processes within the plant for results including:
  • Optimized combustion to reduce fuel usage and lower CO2 emissions
  • Significant reduction of corrosion in the plant
  • Increased plant throughput and availability (waste incineration)
Schematic representation of the overall AGAM system for determining the gas temperature in a power plant furnace. Courtesy Bonnenberg & Dresche)
PC-based control expanded
In the past, the system setup for this measurement and analysis system was implemented conventionally. Up to 16 channels with a 25 kHz clock frequency (i.e., 400,000 values per second) were acquired and processed using a powerful server system for measured value processing and archiving (through methods such as Fourier transformation and correlation). The previous setup also required a PLC for simple automation functions and various special products such as A/D converters for fast, deterministic and high-resolution acquisition of analog signals (sound waves).
In the updated system, PC-based control technology from Beckhoff reduced the number of necessary components to a single machine controller. The CX2062 Embedded PC offers capable performance for the computationally intensive analyses. The many-core CX2062 offers an eight-core Intel  Xeon processor (2.0 GHz clock frequency), and even more powerful processors are available if necessary.
According to Bonnenberg & Drescher, the fast and time-synchronous acquisition and digitalization of the analog signals is particularly important for the quality of the analysis system. The higher the sampling rate, the more accurate the temporal resolution. Also, the lower the jitter, the more accurate the temperature measurement via Fourier analysis and correlation of the measurement channels. For this, the EL3702 EtherCAT analog input terminals provide oversampling functionality. This means the terminals run their own measurement cycle in addition to each fieldbus cycle, which they can use to get even more granular data. The distributed clocks of EtherCAT mean the time resolution is also very precise at +/-20 nanoseconds. What’s more, the entire data set is synchronized and time-stamped with the EtherCAT cycle and the TwinCAT software application with the same accuracy. With the EL3702 EtherCAT Terminal, signals can be acquired at up to 100 kHz, and the number of channels is no longer limited to 16 with the new system.
Modular system increases flexibility
The communication center of a TwinCAT system is the ADS router. From here, the pre-processed data is available to other applications. The data transfer to the C# environment of the AGAM system for further processing is via ADS-DLL. The results then transfer back to the TwinCAT system via ADS and can be forwarded from there to customer systems via common fieldbus interfaces, such as EtherCAT, PROFINET and Modbus, or made available as a visualization web interface in the customer’s network.
On the I/O level, the system is also very easy to expand in Bonnenberg & Drescher’s experience. Existing systems can expand simply by plugging in additional terminals, and only further instances of existing software modules must be formed within the software. The availability of EtherCAT Couplers with fiber-optic interfaces (plastic, multi-mode or single-mode fiber optic) makes the system even more flexible, as this makes it possible to reach distant measuring points and minimize analog wiring.
In front of an AGAM system: Dr. Matthias Ritter (left) and Dr. Martin Brodeck (right), both Managing Directors of Bonnenberg & Drescher, and Ralf Stachelhaus (center), Head of the Beckhoff Rhine-Ruhr, Germany branch office. Courtesy Beckhoff.
Reciprocal control system
The technology has also resulted in significant progress in terms of quality assurance. The necessary simulations use essentially the same system in the measurement technology, just on a reciprocal basis. The components on the boiler are simulated by generating the microphone data via the EL4732 oversampling analog output terminals, and the 24 V signals correspondingly in the reverse direction. Each measurement system undergoes several days of endurance testing before it is delivered to customers.
The modified AGAM-Q1 system has also been available since 2021. It has been approved by German inspection body TÜV and is suitable for use in official and certified temperature measurement in plants. The EL4723 output terminals are used for the legally required self-test of the measurement system.
Measurement setup for acoustic gas temperature measurement (AGAM) by Bonnenberg & Drescher. Courtesy Bonnenberg & Drescher
Overcurrent protection terminals
In the case of the EL9227-5500 electronic overcurrent protection terminal, the initial focus was on its standard use: replacing conventional fuses with an electronic fuse with EtherCAT interface. The many benefits of this include:
  • space and cost savings
  • flexible configuration of tripping current, warning levels for current and voltage, fuse characteristics, starting behavior, etc.
  • complete measurement function of current and voltage as cyclic process data for the PLC (power supply and load diagnostics)
  • extensive diagnostics – for example, with regard to trigger reason, setting changes by users and log files.
In addition, Bonnenberg & Drescher identified another very useful application scenario. The electronic overcurrent protection terminal serves as a digital switching output with measurement and diagnostic functions, namely for solenoid valves. The measurement functions of this EtherCAT Terminal enable the current and voltage characteristics at the switching point to be displayed as trend lines for easy and reliable diagnosis of various valve faults – cable break, coil defect or mechanical defects in the valve.
The CX2062 Embedded PC with the attached EtherCAT Terminals forms a powerful and highly compact control solution for the measurement and analysis system. Courtesy Beckhoff
Fully integrated system
“The integration of measurement data acquisition, archiving, analysis and presentation offers tangible benefits for us,” says Dr. Martin Brodeck, managing director at Bonnenberg & Drescher. “At the start of the measurement chain, special electronics are replaced by standard fieldbus technology. This guarantees the supply of spare parts for decades and ensures that we are continuously involved in innovations without having to dedicate resources ourselves.”
Another important aspect that Brodeck mentioned is the long-term availability of the CX2062 Embedded PC. Like all PC-based machine controllers from Beckhoff, it is available for at least 10 years and subsequently covered by service for a further 10 years – and on a worldwide basis from 40 Beckhoff international subsidiaries as well as partners in more than 75 countries. “Our customers can obtain these components almost anywhere in the world,” Brodeck says.
“The handling of the entire system has been significantly simplified, so it has become much more manageable for our customers. In many cases, they can now help themselves without us having to intervene,” he adds. “What’s more, having the embedded PC as the basis of our platform ensures a successful symbiosis of automation technology and the IT world, which is an invaluable advantage especially for our computationally intensive applications including database connections and web interfaces.”
Ralf Stachelhaus
Ralf Stachelhaus is head of the Beckhoff Rhine-Ruhr, Germany branch office, Beckhoff Automation.
