Compact signal conditioners
Signal conditioners for non-hazardous areas that are extremely compact and UL certified.
Signal conditioners for non-hazardous areas that are extremely compact and UL certified. At just 6 mm wide and 97 mm high, the SC System provides a smaller footprint inside cabinets or in narrow spaces between cable ducts. With an extended temperature range between -25 C and +70 C, the SC System allows maximum flexibility. This unit ensures safe isolation with a 3 kV test voltage and a 300 V working voltage to optimize worker safety and equipment protection. The SC System is designed to withstand high levels of vibration when placed near operational equipment, such as piston engines or breakers.
Pepperl+Fuchs
www.pepperl-fuchs.us.com
