Ball valve provides sanitary and steam service
Igenix Series 5 two-way ball valves use sanitary nonencapsulated or clean steam encapsulated seats in the same body. Valve seat seal can be restored inline to a leak-tight condition, to compensate for normal wear without valve removal.
Igenix Series 5 two-way ball valves use sanitary nonencapsulated or clean steam encapsulated seats in the same body. Valve seat seal can be restored inline to a leak-tight condition, to compensate for normal wear without valve removal. Swing-out and lift-out design simplifies maintenance. Spring-loaded washers create a live-loaded stem assembly for positive sealing. PBM, Inc.
