The pillow-block housing unit is available with either a set-screw or eccentric collar locking system. Designed to be more durable than previous models in both upright and upside-down mounting positions, the housing has flat feet to provide strength, eliminate stress points in recessed corners and prevent accumulation of ambient material under the feet.
The pillow-block housing unit is available with either a set-screw or eccentric collar locking system. Designed to be more durable than previous models in both upright and upside-down mounting positions, the housing has flat feet to provide strength, eliminate stress points in recessed corners and prevent accumulation of ambient material under the feet. The unit is powder-coated in a black epoxy finish for corrosion protection and includes easy-access mounting bolts.
The Timken Co. : www.timken.com
