Wireless pressure transmitter
The AWI-P wireless pressure transmitter is designed for use in rugged industrial areas where accurate pressure measurements are needed. Available in battery-powered and ac-powered versions, the pressure transmitter includes the wireless transmitter, a pressure sensor and self-contained power source in a lightweight aluminum enclosure.
The AWI-P wireless pressure transmitter is designed for use in rugged industrial areas where accurate pressure measurements are needed. Available in battery-powered and ac-powered versions, the pressure transmitter includes the wireless transmitter, a pressure sensor and self-contained power source in a lightweight aluminum enclosure. The pressure transmitter provides tank farms, pipelines, plant and other industrial applications pressure monitoring and measurement without the constraints of hard wiring.
Adalet Wireless
www.adaletwireless.com
