Water batteries just right
Battery Watering Monitor provides maintenance personnel with a fast, convenient, and safe method to visually check electrolyte levels. When installed on a battery, a bright green LED continually blinks as long as the water level is sufficient.
Battery Watering Monitor provides maintenance personnel with a fast, convenient, and safe method to visually check electrolyte levels. When installed on a battery, a bright green LED continually blinks as long as the water level is sufficient. The water level inside the battery is accurately identified by the monitor’s water-sensing probe, which is easily installed inside the battery.
Philadelphia Scientific
www.phlsci.com
Circle 266
