Washdown drives
H2 washdown adjustable speed drives are available in open-loop, encoderless and closed-loop vector, and servo configurations. Rated NEMA 4X, the drives are available from 1 hp through 10 hp. The easy-to-use keypad is integrated into the washdown cover making programming exactly the same as standard H2 drives.
H2 washdown adjustable speed drives are available in open-loop, encoderless and closed-loop vector, and servo configurations. Rated NEMA 4X, the drives are available from 1 hp through 10 hp. The easy-to-use keypad is integrated into the washdown cover making programming exactly the same as standard H2 drives. All H2 drives share identical operator control, field installed options, simple programming and common operating characteristics.
Baldor Electric : www.baldor.com
