Vacuum hose holds size and flexibility
Re-Flex two-ply, reinforced PVC vacuum hose is available in various diameters, including 1, 1 1/4, 1 3/8, 1 1/2, 1 3/4, and 2 in.
Re-Flex two-ply, reinforced PVC vacuum hose is available in various diameters, including 1, 1 1/4, 1 3/8, 1 1/2, 1 3/4, and 2 in. Polyester yarns running helically and longitudinally prevent the hose from elongating under pressure or heat while maintaining flexibility. The hose is easy to cut, couple, and connect using common tools.The Flexaust Co., Inc., www.flexaust.com
Circle 381
