Universal PCI communication card
An eight-port intelligent RS-232 universal PCI communication card, the PCI-1625U is virtually a self-contained computer with an onboard DSP processor that can take over the processing load from the host PC. The PCI-1625U has 1 MB of SRAM that can store serial data and reduce host CPU loading. When the card initializes, it downloads the driver software into its onboard DSP. A universal PCI connector, which is compatible with both the 3.3 V PCI bus and traditional 5 V PCI bus, is standard, as is ICOM Tools, a utility program that test PCI card performance by analyzing port status. The menu commands and toolbar buttons of ICOM Tools act as a PC-based data scope that allows the user to set a trigger condition, capture communications data and monitor signal status. The PCI-1625U is designed for industrial applications where a PC needs to communicate with terminals, modems or other instruments. Up to four PCI-1625U cards can be installed for a total of 32 ports in PCI bus-based PCs.
Advantech Corporation, eAutomation Group
www.eautomationpro.com/us
Advantech Corporation is a CSIA member as of 2/26/2015
Plant Engineering Staff
