Tooling kits
The nested-based tooling kit comprises a 2½-inch surface cutter with replaceable inserts, two 3/8-inch compression bits, two ¼-inch downcut spirals, one ¼-inch compression bit and two 5-millimeter boring drill bits.
The nested-based tooling kit is suitable for most applications. The multiple component cutters are designed to route through layered materials for a larger surface removal. Comprising a 2ble edge cutting tools, four surface cutter inserts and a custom solid wood case for clean and easy storage.
Techno Inc. CNC Cutting Tools
www.techno-isel.com
