Continue to Site
Temperature compensating refractometer
The HydroFlow Automatic Temperature Compensating Refractometer is portable and can be used for most metalworking operations including cutting and grinding fluids.
February 20, 2013
The HydroFlow Automatic Temperature Compensating Refractometer allows plant operators to quickly determine the concentration of metalworking coolants and cleaners, heat-treating fluids, water-based hydraulic fluids, and even plating baths. This simple yet rugged device is portable, and requires no batteries. Its large, easy-to-read scale is available in two ranges: 0-10° Brix and 0-32° Brix. These handy fluid recycling instruments are designed for most metalworking operations, including cutting and grinding fluids, synthetic machining fluids, plating and acid baths, cleaner baths, water-based hydraulic fluids, die lubricants and chromating solutions.
ErieZ
www.eriez.com
Related Resources
