Syphon elbow
Constructed of stainless steel to provide corrosion resistance, the pinless syphon elbow is designed for use in steam-heated rotating cylinders.
By Plant Engineering Staff September 15, 2008
Constructed of stainless steel to provide corrosion resistance, the pinless syphon elbow is designed for use in steam-heated rotating cylinders. The patent-pending design eliminates the hinge pin and features an integral locking mechanism that secures the elbow in position and increases the robustness of the syphon system. Intended for installation on blind rolls or rolls with hand-hole access, the 45-degree unit results in less cantilever weight compared to longer, bent syphon pipes.
Kadant Johnson, Inc.
www.kadant.com
