Solid lubricant outlasts bearing greases
MicroPoly porous, oil-filled polymer releases lubricant during bearing operation and requires little cleanup or maintenance. The solid lubricant outlasts oil-based greases 2 - 12 times and is available in formulas that are FDA and USDA compliant. PhyMet
MicroPoly porous, oil-filled polymer releases lubricant during bearing operation and requires little cleanup or maintenance. The solid lubricant outlasts oil-based greases 2 – 12 times and is available in formulas that are FDA and USDA compliant.
PhyMet
