The Series 3505 solenoid valves for air, water, emulsion and inert gas control are two-way, two-position, closed or open valves that feature a forged brass body and an encapsulated coil construction. The valves have a zero minimum pressure differential, a full-flow 1/2-inch orifice and are available in 1/4, 3/8 and 1/2-inch NPT.
The Series 3505 solenoid valves for air, water, emulsion and inert gas control are two-way, two-position, closed or open valves that feature a forged brass body and an encapsulated coil construction. The valves have a zero minimum pressure differential, a full-flow 1/2-inch orifice and are available in 1/4, 3/8 and 1/2-inch NPT. The valves handle pressures as high as 230 psi and operate in temperatures ranging from -10 to 50 degrees C.
Spartan Scientific
www.spartanscientific.com
