Solenoid pipeline valve pneumatics
The NITRA line of pneumatics are two-position, normally-closed, and are fitted with DIN-style wire connectors
January 7, 2014
The NITRA line of pneumatics include a wide selection of solenoid pipeline valves designed for control of air, oil, water, and inert gas. All valves are two-position, normally-closed, spring return styles with 24VAC, 24VDC or 120 VAC solenoids, and are fitted with DIN-style wire connectors. Depending on series, valves are offered with port sizes from 1/8-inch to one-inch FNPT. Valve models are available in two-way and three-way diaphragm styles. NITRA pipeline valves are ideal for applications such as pneumatic air line shutoff and HVAC systems.
AutomationDirect
www.automationdirect.com
Related Resources
