Single-axis actuators come in 208 configured styles.
Single-axis actuators come in 208 configured styles. Each unit is a ball-screw-driven device constructed of an extruded 6063-T6 aluminum base with a black anodized finish and 1045 steel side supports. Features include a linear slide for medium or heavy loads, a grooved base for sensor mounting, a top plate with tapped holes for switch flags on both sides and a tight-tolerance bore motor bracket that accepts most 30 to 400-W servos. Maximum velocities are available to 1055mm/sec. Misumi USA, Inc.
www.misumiusa.com
