Shock recorder
The OM-CP-ULTRASHOCK101-50 -EB is a battery powered, three-axis shock recorder that measures and records temperature, pressure and humidity at the selected reading rates, while shock is recorded at the peak acceleration levels. The device will measure and record up to 170,000 measurements per channel.
By Plant Engineering Staff January 15, 2008
The OM-CP-ULTRASHOCK101-50 -EB is a battery powered, three-axis shock recorder that measures and records temperature, pressure and humidity at the selected reading rates, while shock is recorded at the peak acceleration levels. The device will measure and record up to 170,000 measurements per channel. The CE-compliant recorder plugs into a COM or USB port. Typical battery life is 60 days with six D-cell alkaline batteries. Recommended applications include machine vibration analysis and vehicle vibration monitoring.
Omega Engineering Inc.
www.omega.com
