Rotary torque sensor
Model 01424 series sensor incorporates a digital wireless system and features reduced electrical noise, a 1,000-Hz frequency response and a 10,000 rpm speed rating. The sensor is designed to measure rotational torque using a conventional, shaft-to-shaft configuration for inline placement. It is capable of measuring torque from DC motors, engines, turbines and other rotary power sources.
Model 01424 series sensor incorporates a digital wireless system and features reduced electrical noise, a 1,000-Hz frequency response and a 10,000 rpm speed rating. The sensor is designed to measure rotational torque using a conventional, shaft-to-shaft configuration for inline placement. It is capable of measuring torque from DC motors, engines, turbines and other rotary power sources. It can also be supplied with a 512-ppr optical encoder to measure angle or speed.
Sensor Developments, Inc.
www.sendev.com
