Rotary screw air compressors with variable speed drive that increases energy efficiency by up to 35 percent.
Rotary screw air compressors with variable speed drive that increases energy efficiency by up to 35 percent. These units are designed to improve overall system efficiency by ensuring low pressure drops. It delivers specific energy output and premier airflow capacity for each compressor application. The compressors are designed to withstand harsh plant conditions and can run continuously in ambient temperatures of up to 115 degrees Fahrenheit. The starter panel meets NEMA 12/IP55 protection ratings to provide protection against circulating dust, falling dirt and dripping or splashing liquids. The RS30n and RS37n compressors decrease energy use during start-up, which can draw up to 800% of the full load current. The compressors limit the in-rush current during start-up, minimizing peak power charges and lowering energy usage.
Ingersoll Rand
www.ingersollrand.com
