Rotary encoders
T-Line 40-mm series incremental rotary encoders are available in standard inch shaft and coupling sizes. The encoders come standard with an integral 2-meter cable, and provide output resolution up to 1,024 ppr in an IP54-rated housing. They require a 4.75-30 Vdc supply voltage. The encoders are ideal for most light- to medium-duty applications in the material handling, packaging and printing in...
October 1, 2009
T-Line 40-mm series incremental rotary encoders are available in standard inch shaft and coupling sizes. The encoders come standard with an integral 2-meter cable, and provide output resolution up to 1,024 ppr in an IP54-rated housing. They require a 4.75-30 Vdc supply voltage. The encoders are ideal for most light- to medium-duty applications in the material handling, packaging and printing industries. TVI40 solid shaft encoders are available with 1/8 inch and 1/4 inch shaft sizes. THI40 hollow shaft encoders are available with 3/16 inch,
Pepperl+Fuchs
www.pepperl-fuchs.com
