CRV variable operation dryers are controlled by a microprocessor and feature an all-in-one, patented heat exchanger technology. The design also features an inverter for operation at medium to high air flows. Cycling operation takes place at lower air flows, with compressor cycling on and off according to the effective load on the dryer.
CRV variable operation dryers are controlled by a microprocessor and feature an all-in-one, patented heat exchanger technology. The design also features an inverter for operation at medium to high air flows. Cycling operation takes place at lower air flows, with compressor cycling on and off according to the effective load on the dryer. Maximum ambient temperature is 122 F; maximum inlet temperature is 140 F.
domnick hunter : www.domnickhunter.com
