Continue to Site
Ratchet useful for tight places
Blackhawk Rotator Ratchet looks and works like a standard ratchet and requires only a 6-degree arc swing. The tool is unique because it offers an alternative way to work. Twisting the handle causes a set of internal gears to engage to turn the socket. The handle will rotate 360 degrees in either direction and turn the socket in the same direction no matter which way it is twisted.
By Staff November 1, 2005
Blackhawk Rotator Ratchet looks and works like a standard ratchet and requires only a 6-degree arc swing. The tool is unique because it offers an alternative way to work. Twisting the handle causes a set of internal gears to engage to turn the socket. The handle will rotate 360 degrees in either direction and turn the socket in the same direction no matter which way it is twisted. This is ideal for tight places. Stanley-Proto : www.stanleyproto.com
TO VOTE, WRITE 70 ON BALLOT
For more information, write 70 on card
