PT-516 high capacity pump trap is a low maintenance, nonelectric solution to moving large amounts of condensate from low points, low pressures, or vacuum spaces to areas of higher elevation or pressure.
PT-516 high capacity pump trap is a low maintenance, nonelectric solution to moving large amounts of condensate from low points, low pressures, or vacuum spaces to areas of higher elevation or pressure. The unit has a capacity in excess of 60,00 lb/hr, and can return condensate at temperatures well above the 210 F limit of conventional electric pumps without leaking seals or cavitation concerns.
Armstrong Intl., Inc.
www.armstrong-intl.com
