Pump moves hot fluids without water cooling
HTO 300 close-coupled, end-suction, centrifugal pump has an air-cooled seal housing design to eliminate an external water cooling jacket when pumping fluids up to 650 F. A carbon graphite bushing isolates the seal cavity and limits heat transfer.
HTO 300 close-coupled, end-suction, centrifugal pump has an air-cooled seal housing design to eliminate an external water cooling jacket when pumping fluids up to 650 F. A carbon graphite bushing isolates the seal cavity and limits heat transfer. A fan clamp keeps the seal housing at an optimal temperature to extend seal life. Flow rates range up to 450 gpm with heads to 190 ft TDH. MP Pumps, Inc.
