Dura-Drive Plus motorized pulley design is a heavy-duty drum motor in which the body rotates around a stationary shaft. The rotating outer drum becomes the pulley drive to power a conveyor belt system.
Dura-Drive Plus motorized pulley design is a heavy-duty drum motor in which the body rotates around a stationary shaft. The rotating outer drum becomes the pulley drive to power a conveyor belt system. The internal motor and parallel gear drive replaces external motors, gear boxes, chains, and V-belts, as well as safety guards and brackets.Sparks Belting Co.
Circle 378
