PROFINET bus coupler
The 750-340 Series bus coupler is designed as local or distributed I/O on a PROFINET industrial Ethernet network. It includes automatic configuration, a 10/100 Mbps data rate and support for many common Ethernet protocols such as HTTP, BootP, DHCP, DNS, SNTP, FTP, SNMP and SMTP for system management and diagnostics.
The 750-340 Series bus coupler is designed as local or distributed I/O on a PROFINET industrial Ethernet network. It includes automatic configuration, a 10/100 Mbps data rate and support for many common Ethernet protocols such as HTTP, BootP, DHCP, DNS, SNTP, FTP, SNMP and SMTP for system management and diagnostics. Housed in a modular, compact (2 x 2.56 x 3.94-inch), DIN-rail-mount design, the 750-340 fits in small spaces. It is compatible with most 750 and 753 Series I/O modules offering access to more than 200 digital, analog and special function I/O modules.
Wago Corp.
www.wago.com
