The Pivotrol PTF4 high-capacity pressure-powered condensate pump is capable of pumping up to 40,000 pounds per hour in rapid-cycling process environments and under elevated pressure and temperature conditions. A patented, pressure-balancing body ensures the unit's dual pumping mechanisms share the pumping load equally.
The Pivotrol PTF4 high-capacity pressure-powered condensate pump is capable of pumping up to 40,000 pounds per hour in rapid-cycling process environments and under elevated pressure and temperature conditions. A patented, pressure-balancing body ensures the unit’s dual pumping mechanisms share the pumping load equally. Patented vent-assist valves release pressure in the pump body during the exhaust stroke.
Spirax Sarco, Inc. : www.spiraxsarco.com/us
