Plastic pumps bolted for easy maintenance
SandPIPERII plastic pumps are available in sizes from 1-3 in. with a maximum flow of 260 gpm. The pumps have a bolted design and V-band clamps are not used, which results in stronger construction and easier maintenance.
SandPIPERII plastic pumps are available in sizes from 1-3 in. with a maximum flow of 260 gpm. The pumps have a bolted design and V-band clamps are not used, which results in stronger construction and easier maintenance. The latest design of a no-lube, nonstall air valve increases energy efficiency. The modular air valve tolerates wet and dirty air.
Warren Rupp, Inc.
www.warrenrupp.com
Circle 392
