The Spectrum 375 X-treme plasma cutter weighs 18 pounds and can connect to any single-phase power supply ranging from 115 to 230 V. Rated at 3/8-inch cutting capacity on mild steel and ΒΌ-inch capacity on aluminum, the unit is designed for maintenance and HVAC applications, among others. An internal filter and factory-set regulator eliminates the need for the operator to adjust air pressure.
Miller Electric Mfg. Co. : www.millerwelds.com
