Pipeline mixers
The Greerco pipeline mixer for continuous, high-speed, high-shear processing is designed for applications involving homogenization, mixing, dispersion and emulsion. The mixer features a skewed turbine/stator unit that operates at tight tolerances to produce high-shear axial mixing. The unit is suitable for a wide range of applications in the cosmetic, chemical, pharmaceutical, petrochemical and...
The Greerco pipeline mixer for continuous, high-speed, high-shear processing is designed for applications involving homogenization, mixing, dispersion and emulsion. The mixer features a skewed turbine/stator unit that operates at tight tolerances to produce high-shear axial mixing. The unit is suitable for a wide range of applications in the cosmetic, chemical, pharmaceutical, petrochemical and food industries. Standard features include 316 stainless-steel construction and single mechanical seals with other options available.
Chemineer Inc.
www.chemineer.com
