Y2K-2000 filter cart is capable of transporting a drum of oil and the transfer pump/filter with a single piece of equipment. Currently, plants use a minimum of two pieces of equipment to accomplish the same job.
Y2K-2000 filter cart is capable of transporting a drum of oil and the transfer pump/filter with a single piece of equipment. Currently, plants use a minimum of two pieces of equipment to accomplish the same job. A breather adapter provides 3-micron air filtration and water removal as the oil level drops in the drum. Options include an analysis kit for periodic testing of oil contents.
Y2K Fluid Power, Inc.
www.bcity.com/y2kfluidpower
Circle 381
