Network bridge provides Ethernet-based DAQ solution
Ethernet bridge connects anything using standard Modbus protocol to plant local area networks using Ethernet, TCP/IP, and Modbus/TCP protocols.
Ethernet bridge connects anything using standard Modbus protocol to plant local area networks using Ethernet, TCP/IP, and Modbus/TCP protocols. Low-cost, simple way for Modbus-compatible devices to realize the performance of Ethernet connectivity, the bridge supports multiple devices on the serial line and multiple Modbus TCP connections.
Schneider Electric/Lantronix; www.schneiderautomation.com
TO VOTE, WRITE 63 ON BALLOT
For more information, circle 68 on card
