Meters measure flow parameters
VelociCalc Plus meters simultaneously measure and log temperature, humidity, differential pressure, and velocity from a thermal anemometer or Pitot tube.
VelociCalc Plus meters simultaneously measure and log temperature, humidity, differential pressure, and velocity from a thermal anemometer or Pitot tube. The meter can also calculate volumetric flow rate, wet bulb temperature, dew point, heat flow, and convert between actual and standard readings.
TSI, Inc.
