SureSite externally-mounted, magnetic, visual liquid level indicators are built in accordance with the requirements of the ANSI/ASME boiler and pressure vessel codes. They are designed to handle pressures to 420 psi and temperatures to 750 F.
SureSite externally-mounted, magnetic, visual liquid level indicators are built in accordance with the requirements of the ANSI/ASME boiler and pressure vessel codes. They are designed to handle pressures to 420 psi and temperatures to 750 F. Materials of construction include 316 stainless steel, Hastelloy and copper/nickel alloy, PVC, and chemically inert PVDF. Switch modules provide high, low, and intermediate alarms.
Gems Sensors, Inc.
www.gemssensors.com
Circle 373
