A rebuildable Nyliner bushing bearing is detailed in a 4-p technical bulletin. The literature explains how the bearing's unique design uses two self-lubricating engineered polymer snap-in inserts to provide fast breakin, reduced wear, and long life.
A rebuildable Nyliner bushing bearing is detailed in a 4-p technical bulletin. The literature explains how the bearing’s unique design uses two self-lubricating engineered polymer snap-in inserts to provide fast breakin, reduced wear, and long life. The bearing is used for linear and rotary motion at speeds up to 400 fpm.
Thomson Industries, Inc.
www.thomsonindustries.com
