Isolator protects bearings
Micro-Tec II bearing isolator has a microcellular filter to block out airborne and vapor contamination. A unitizing element ensures no internal metal-to-metal contact and there is no wear on shafts or metallic components. A Cam-Lock design allows easy installation without using an arbor press. The seal surpasses NEMA MG 1-2003 and IEEE 841-2001 standards.
By Staff November 1, 2005
Micro-Tec II bearing isolator has a microcellular filter to block out airborne and vapor contamination. A unitizing element ensures no internal metal-to-metal contact and there is no wear on shafts or metallic components. A Cam-Lock design allows easy installation without using an arbor press. The seal surpasses NEMA MG 1-2003 and IEEE 841-2001 standards. Klozure Dynamic Seals, Bearing Isolator Div. : www.microtec2.com
TO VOTE, WRITE 332 ON BALLOT
For more information, write 332 on card
