Instruments and controls – 2005-01-10
Self-configuring level meter
OPTIFLEX 1300 C TDR level meter measures distance, level, and volume of liquids, pastes, and solids. It is available with five different probes — single rod, double rod, single cable, double cable, and coaxial. Meter’s maximum measuring range is from 13-115 ft, depending on the probe type. Installation and setup requires user to fit the gauge to the tank, wire it, and turn it on. A Setup Wizard asks questions to define the tank and the product to be measured.
KROHNE, Inc. krohne.com Write 300 on PE card
Analog-style voltmeter
SP5 1710-BL voltmeter has a large LCD that shows a 17-position analog-style display. The voltmeter has a full-scale deflection of 1 V with needle indication that can be center or left justified. Display features permanent color scale and markers to identify measurement status. Ultra low profile, splash proof housing contains green LED backlight.
Lascar Electronics, Inc. lascarelectronics.com Write 301 on PE card
Pressure transmitter
Series 626-GH industrial pressure transmitter offers 0.25% full-scale accuracy whether measuring vacuum or pressure. Unit can be vacuum, combination vacuum and pressure, or pressure. Standard pressure ranges are 0—5 to 0—5000 psig. Stainless steel transmitter can be used to sense pressure of air, compatible gases, and liquids.
Dwyer Instruments, Inc. dwyer-inst.com Write 302 on PE card
Pressure transducer
Model 528 strain gauge pressure transducer is designed for robust industrial and submersible applications such as hydraulic test, bore-hole level, and vehicle test applications that require high performance in extreme environments. Suitable for semiconductor processing, robotics, natural gas equipment, power plants, HVAC compressors, and refrigeration, unit’s strain gauge design is resistant to aging, and thermal transients.
Setra Systems, Inc. setra.com Write 303 on PE card
Paperless recorder
RD8900 series paperless recorder saves space, requiring less than 7 in. behind panel. Unit monitors, records, and evaluates data from many automation applications, and presents them in real time on a high-resolution, color display. Users can access data on the screen, as well as from a remote site via standard Ethernet or optional serial interface. Historical data may be stored in flash ROM, compact flash card, or remote host PC for evaluation and printout.
Omega Engineering, Inc. omega.com Write 304 on PE card
Remote I/O modules
BusWorks 900EN series I/O modules interface up to 12 analog or discrete I/O signals to an EtherNet/IP network. Each remote I/O module can operate independently of a buscoupler. Available modules include discrete I/O; analog input modules, which interface dc voltage, current, or temperature signals from sensors to the network; and analog output modules, which provide dc current or voltage control signals for displays, drives, or other analog devices.
Acromag, Inc. acromag.com Write 305 on PE card
Clamp-type ground tester
DET10C and DET20C ground testers are designed to measure earth/ground resistance and current flow without disturbing existing connections. Testers employ clamp-on technology, ensuring safety and convenience. Units are suitable for measuring resistance and continuity of grounding loops around pads and buildings, as well as inspecting and verifying lightning protection systems.
Megger megger.com Write 306 on PE card
Paperless chart recorder
Model RH520 humidity and temperature paperless chart recorder may be desk or wall mounted and provides simultaneous numerical and graphical displays of humidity from 20%—95% RH and temperature from -20 to 140 F. Recorder also calculates dew point. Multiple graphic displays are cursor controlled and have adjustable X/Y axis resolution, allowing users to monitor both temperature and humidity within user-specified range.
Extech Instruments acromag.com Write 307 on PE card
Digital color camera
TMC-6700CL progressive scan CCD digital color camera features
JAI Pulnix, Inc. jaipulnix.com Write 308 on PE card
